Thread: 3 Axis CNC router
06-05-2016 #231
To heat my workshop... Someone is lending me a couple of them. A minimum of 16 deg C as a constant temp is recommended and West System state: "As the temperature drops, epoxy becomes proportionally thicker, reducing its ability to flow out." They also state that air bubbles are more of an issue at lower temperatures.
07-05-2016 #232
Hi Joe
If you have a vacuum pump you could knock up a degassing pot, i use an old pressure cooker.
Regards
Mike
07-05-2016 #233
Hot air gun across surface would usually deal with any bubbles.
09-05-2016 #234
09-05-2016 #235
Best of luck, looks like you've got everything prepared though so I'm sure it'll go fine.
09-05-2016 #236
careful with the heat gun joe you can easily cause hot spots which harden at different rate. Only a quick flash is needed and only if really needed. Few air pockets won't hurt anything.
Not quite sure what the vasoline is for thou.?
09-05-2016 #237
09-05-2016 #238
10-05-2016 #239
The Following 2 Users Say Thank You to JoeHarris For This Useful Post:
10-05-2016 #240
Great stuff especially the time lapse video. It might be worth keeping the bridge between the 2 rails in place during initial setting up if you need a datum to DTI off to align the gantry Y rails - depending on the gantry rail design you've decided on
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
