Page 26 of 66 FirstFirst ... 16242526272836 ... LastLast
  1. Has anyone got any experience of these?
    https://www.cnc4you.co.uk/Stepper-Mo...H401-03-Nema23
    Was wondering if it might be man enough to belt drive my x-axis??? I have no real issue with a nema 34 and 240v drive but would the 4nm nema 23 be faster..? The old issue of wanting this machine to do wood and aluminium! And remembering I have 5mm pitch screws.
  2. #252
    I've got an 8Nm Nema 34 in my X axis and 240V drive but 10mm pitch screws....you could always go 2:1 on the pulleys. I cut plastics at 7500mm/sec and that's plenty quick enough 😁
    How heavy is your X axis?
    Neil...
    Build log...here
  3. #253
    Lives in Marple Stockport, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Neil Are you sure
  4. The Following User Says Thank You to Clive S For This Useful Post:
  5. I'm not sure on the weight, not crazy as it is ali extrusion and 20mm plate - pretty standard L design! It wasn't standard when I started but people keep starting and finishing their builds while I keep trudging along at a snails pace! I was planning on going 2:1. Have you cut much wood - how slow can you go?!
  6. Quote Originally Posted by Clive S View Post
    Neil Are you sure
    Per min I'm guessing!
  7. #256
    Neil Are you sure
    Oops....its late and I was moving house all weekend....still at the old rented house now touching up paint, filling holes etc.....
    Neil...
    Build log...here
  8. Quick progress shot to prove I haven't given up!
  9. #258
    Quote Originally Posted by JoeHarris View Post
    Erm....yes...per sec would be going some!!!!!
    Neil...
    Build log...here
  10. Quote Originally Posted by njhussey View Post
    Bet your glad your machine is a work! I don't fancy moving this beast!
  11. #260
    Too right....had to use the forklift once it was on its frame, far too heavy to lift!
    Neil...
    Build log...here
  1. BUILD LOG: 3 Axis Router
  4. 3 axis cnc/router bed
