Thread: 3 Axis CNC router
03-10-2016 #251
Has anyone got any experience of these?
https://www.cnc4you.co.uk/Stepper-Mo...H401-03-Nema23
Was wondering if it might be man enough to belt drive my x-axis??? I have no real issue with a nema 34 and 240v drive but would the 4nm nema 23 be faster..? The old issue of wanting this machine to do wood and aluminium! And remembering I have 5mm pitch screws.
03-10-2016 #252
I've got an 8Nm Nema 34 in my X axis and 240V drive but 10mm pitch screws....you could always go 2:1 on the pulleys. I cut plastics at 7500mm/sec and that's plenty quick enough 😁
How heavy is your X axis?
Sent from my HUAWEI VNS-L31 using TapatalkLast edited by njhussey; 03-10-2016 at 10:18 PM.
03-10-2016 #253Neil Are you sureI cut plastics at 7500mm/sec and that's plenty quick enough 😁
03-10-2016 #254
I'm not sure on the weight, not crazy as it is ali extrusion and 20mm plate - pretty standard L design! It wasn't standard when I started but people keep starting and finishing their builds while I keep trudging along at a snails pace! I was planning on going 2:1. Have you cut much wood - how slow can you go?!
03-10-2016 #255
03-10-2016 #256
03-10-2016 #257
Quick progress shot to prove I haven't given up!
03-10-2016 #258
03-10-2016 #259
03-10-2016 #260
Too right....had to use the forklift once it was on its frame, far too heavy to lift!
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
