Thread: 3 Axis CNC router
27-04-2017 #381
27-04-2017 #382
Thanks Neale, The terminals are overkill in terms of size and will take two cables each but as I've shown on the circuit diagram the plan is to take one feed from the terminals on the power supply to some din terminal blocks with a jumper bar to provide as many as I need...
27-04-2017 #383
Sounds fine. My PSU was originally bought from Zapp, although I have now changed the transformer in it, but it came with three pairs of output terminals already. Then I fitted it in a control box with four stepper drivers...
Must confess that I didn't actually put a wiring diagram together for mine, just some sketches to work out roughly what was needed. Then I set to work with a pile of cable reels, big box of ferrules and crimping tool, and quite a lot of black coffee. Don't try this one at home
Still, it does seem to work OK.
27-04-2017 #384
27-04-2017 #385
It's great when a plan comes together! Well done. All downhill from here...
27-04-2017 #386
28-04-2017 #387
Moving along nicely, very professional work!
30-04-2017 #388
Looking good!
It is hard to see from the pictures, but please check soldering of the capacitors.
Sent from my LG-H850 using Tapatalk
30-04-2017 #389
30-04-2017 #390
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
yep crack on!
