Page 39 of 66 FirstFirst ... 29373839404149 ... LastLast
  1. Quote Originally Posted by routercnc View Post
    If you got 50V in post 373 at the rectifier then so long as capacitors are correct way around then should work . . . Only one way to find out
    yep crack on!
  2. Quote Originally Posted by Neale View Post
    Only comment (if you have a chance to make any small mods at this stage) is to add a few more sets of terminal contacts for the output, all wired in parallel. This allows you to run separate power feeds to each stepper driver, rather wiring them daisy-chain fashion, and it's easier than trying to stick three big wires in the same terminal. Not sure if it really make a difference in our class of machine but it is generally considered good practice not to share high-power connections between devices, and it's a lot easier if you have multiple terminals available. Might be able to put multiple spade terminals on each of your contacts, though?
    Thanks Neale, The terminals are overkill in terms of size and will take two cables each but as I've shown on the circuit diagram the plan is to take one feed from the terminals on the power supply to some din terminal blocks with a jumper bar to provide as many as I need...
  3. #383
    Sounds fine. My PSU was originally bought from Zapp, although I have now changed the transformer in it, but it came with three pairs of output terminals already. Then I fitted it in a control box with four stepper drivers...
    Must confess that I didn't actually put a wiring diagram together for mine, just some sketches to work out roughly what was needed. Then I set to work with a pile of cable reels, big box of ferrules and crimping tool, and quite a lot of black coffee. Don't try this one at home Still, it does seem to work OK.
  4. Quote Originally Posted by Neale View Post
    Ha yes I would definitely fail with that approach so well done!
    Well I've plugged it in and...
    It works! Hooray, my first functioning bit of electronics for this machine!
  5. #385
    It's great when a plan comes together! Well done. All downhill from here...
  6. Quote Originally Posted by Neale View Post
    Thanks Neale wish I believed that! Still, well chuffed with that thanks everyone for the help.
  7. #387
    Moving along nicely, very professional work!
  8. #388
    Looking good!
    It is hard to see from the pictures, but please check soldering of the capacitors.
    Sent from my LG-H850 using Tapatalk
  9. Quote Originally Posted by Nickhofen View Post
    Thanks!
  10. Quote Originally Posted by toomast View Post
    Looking good!
    Hi Toomast, the terminals on the caps have been pushed through the wire stands and then soldered, I have also put some hot glue over the bare wire to help prevent shorts.
There are currently 15 users browsing this thread. (0 members and 15 guests)
  1. BUILD LOG: 3 Axis Router
  4. 3 axis cnc/router bed
