Page 40 of 66 FirstFirst ... 30383940414250 ... LastLast
  1. #391
    Quote Originally Posted by JoeHarris View Post
    Hi Toomast, the terminals on the caps have been pushed through the wire stands and then soldered, I have also put some hot glue over the bare wire to help prevent shorts.
    Good, maybe the glue makes it look odd on the picture. It can be tricky to get the thicker wires to heat up properly - risk of cold solder joint.
  2. In the interests of completeness of my build log and in the hope that it may help demystify building your own power supply here are a couple of videos of my power supply build. Although it is obvious to me, I will point this out for any with less common sense - working with electricity, particularly mains can be very dangerous. If you want to build your own psu then you can take it from me, a totally amateur, that it is perfectly doable if you ask the right people the right questions. Please post your design and invite comment before embarking on a project like this. You need to consider what the right transformer, rectifier, capacitors and fuse will be before starting and do your research, because connecting it all up wrong will be disastrous. Thanks to Dean, Clive and Barry in particular (as always) for the tips and guidance. Ps any comments on my very basic explanation in the second video (about 12mins in) will be gratefully received although I except from the outset that it is basic!!
    https://youtu.be/4OoQQg76ar4
    https://youtu.be/WISDqx-e23M
  3. The Following User Says Thank You to JoeHarris For This Useful Post:
  4. #393
    Hi Joe,
    First off, thanks for the fantastic build thread and video logs - keep them coming please! I've been getting more seriously into the initial design phases, had made some starting choices, then came across your build. Looks to me like you've encompassed the majority of the good advice out there, and then some more! I suspect when I get to a final design, it won't look too dissimilar to your own :)
    Secondly, enjoyed watching your video this morning over breakfast - very well explained. Hadn't ever considered that the voltmeter was measuring RMS so UK mains peak-to-peak is sqrt(2)*240V. Only comment is that sometimes the audio balance in your videos is off - loud music, quiet talking! May just be me!
  5. Quote Originally Posted by AndyUK View Post
    Hi Joe,
    Fair comment on the audio I'll try and sort that on the next one. Unfortunately I'm not kitted out for quality filming or editing - camera = my phone, editing on my phone, music = my phone... so pretty low tech!!
  6. Quote Originally Posted by AndyUK View Post
    Hi Joe,
    There are some things I would do differently now so make sure you post your designs for feedback before you spend any money!
  7. Hi everyone, I've managed to get a working mockup of the e-stop circuit together... another little video:
    https://youtu.be/OUgjcH8JGMs
    As always any comments gratefully received!
  8. Can anyone explain what this is??
  9. #398
    That is an interface converter that transforms a 0-10V analog signal to 0-20mA
  10. #399
    Lives in Marple Stockport, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    This is it http://uk.rs-online.com/web/p/signal...oning/4184859/
    I think they are used in industry to remote measure sensors etc over a two wire system like this;-
    https://www.acromag.com/sites/defaul..._Loop_904A.pdf
    http://www.murata-ps.com/data/meters/dms-an20.pdf
  11. The Following User Says Thank You to Clive S For This Useful Post:
  12. Quote Originally Posted by Clive S View Post
    Thanks Clive, I had found it on RS but it still didn't mean a lot!! I have bought a second hand cabinet and it came with a few bits and bobs left inside there were a couple of these which I did not recognise- don't think they will be all that useful! eBay...
  1. BUILD LOG: 3 Axis Router
  4. 3 axis cnc/router bed
