Thread: 3 Axis CNC router
06-09-2017 #451
The Following User Says Thank You to JoeHarris For This Useful Post:
06-09-2017 #452
It was Clive that put me on to you and convinced me I could build the supply. It looks really simple but at the same time I can totally understand the fear lol I was petrified but now I think it'll be relatviely easy just trying to work out if I can cram this into an ATX power supply casing if I move the fan externally and add a 2nd fan either so it blows in one side and sucks out the other.
I want to try and fit the stepper drivers and self build PSU in a PC mini tower case with a whole pc as well.
I have a mini 80plus PC power supply I can fit somewhere in the case (It's about 1/3 size of ATX) and I think I can put the AM882 where the drive bays are. I could ditch the Hard disk and run from a fast USB flash drive or SD card it will be quick enough for linuxcnc. Or I could mount the hard disk somewhere else. I think as long as the PSU's extract their heat to the air and I add a bathroom extractor fan as well for the pc and stepper driver waste heat I'll be ok. Maybe add an active intake as well sucking air a distance away from the extraction point.Last edited by Desertboy; 06-09-2017 at 08:49 AM.
06-09-2017 #453
Joe A picture paints a thousand words I tend to point people to your P/S vids (if that is ok) as they are an excellent way to show how easy they are to build. There is one point and you have it correct is that you must not but an earth (ground) to the bolt on the top of the transformer that runs through it. It is ok at the bottom end ie the plate.
The Following 2 Users Say Thank You to Clive S For This Useful Post:
06-09-2017 #454
06-09-2017 #455
No worries Clive - just glad they are of some use to people!
Btw I have made a playlist of the two videos here to keep them together: https://www.youtube.com/playlist?lis...zD30sZjtp_VyqYLast edited by JoeHarris; 06-09-2017 at 07:35 PM.
06-09-2017 #456
14-09-2017 #457
Another little part made...
15-09-2017 #458
Beautiful!!
15-09-2017 #459
Just stunning work, made me realise I forgot to buy a vice yet ;)
15-09-2017 #460
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
