Thread: 3 Axis CNC router
25-10-2017 #481
That looks about right.
25-10-2017 #482
25-10-2017 #483
26-10-2017 #484
Limit switch circuit:
Home proximity switch circuit:
27-10-2017 #485
Can i ask a question about limit switches / estop wiring here since it is kind of on topic? Dont want to hijack this topic.
When hitting estop/limit switches, can 68volts be shutoff.. or should/can the enable contact on the drives be used?
BTW Joe the hand drawn schematics look very good.
Grtz Bert.
27-10-2017 #486
Joe - that looks fine, except that you don't need to use three inputs on the CSMIO for the limit switches. They can all go into one input, and in the Mach3 configuration screen you point all the max and min limits for all axes at that pin. You are using home switches separate from the limit switches. No problem with that, and the wiring looks OK. I'm assuming that you have NPN NC switches. By using separate inputs for the home switches you give yourself the possibility to home more than one axis at a time. Typically, you might configure Mach3 to home Z (to get it high up out of the way) and then home X and Y simultaneously - saves a little bit of time during the homing sequence.
Bert - some people consider hitting a limit switch to be an "emergency" so you could wire them in series with the e-stop switches. Personally, I have the e-stop switches trip the safety relay which turns off the 68V PSU, and also disables the drivers via the "enable" inputs and sends a signal to the CSMIO e-stop connection. My limit switches (like Joe's diagram) just go the CSMIO. Part of the reason for this is that I use a single switch for limit and home at one end of each axis, and I don't want a home switch to operate as an e-stop!
The Following 2 Users Say Thank You to Neale For This Useful Post:
27-10-2017 #487
27-10-2017 #488
28-10-2017 #489
28-10-2017 #490
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
