Thread: 3 Axis CNC router
21-04-2020 #11
CamBam is another I didn't get on with and I found it limited in what it could do, but that was a long time ago, I'm sure it's come on since.
Most likely a bad wire if it's in this area, I'd be amazed if it's the Cslabs output as they are generally bulletproof.
No problem, we will get you going in no time Joe. It will be something silly, usually is.!
Joe just try this for me because I've had this happen before just on Z axis where it won't Jog but it will move with a command... So Do an MDI move.
Make sure got enough room for Z to move Then Zero it out on the DRO and type G1 Z -10 (note the Minus) F500 into the MDI command bar and see if it moves.
Let me know how get on.
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
