Thread: 3 Axis CNC router
23-05-2020 #641
Hi
Version 22 of Mach 3 is working way better! Here’s a video of my first proper little project. No issues
https://youtu.be/JBjDpcFo2nk
23-05-2020 #642
Good stuff - I was happy with .028 but I doubt that there's much difference. Only key feature is whether or not it works!
23-05-2020 #643
24-05-2020 #644-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
24-05-2020 #645
24-05-2020 #646
That Hangboard's a cool little project. Very nice indeed.
Wal.
The Following User Says Thank You to Wal For This Useful Post:
16-06-2020 #647
I have completed a few successful projects now, pocketing, profiling and v-carving, all without much of a hitch. But trying some 3D (2.5D) carving has resulted in my z axis behaving badly again! Part way though a roughing toolpath the z axis started moving a little erratically and then stalled a few times (I think). It moved up and started milling above the work piece. I pressed feedhold then stopped the machine, the spindle stopped but the z axis kept making jolting movements in an upward direction?! It only stopped it's mad movements when I hit the emergency stop. I am going to throttle back the motor tuning some more on Z to see if it relates to that, but it seems very odd to me that it would carry on moving after being told to stop. Has anyone else had a similar issue?
16-06-2020 #648
Don't know why it's doing this never seen it before but the reason it kept going after feed hold was because it was emptying the buffer.
Have you done a check to see if your missing steps from the pulse being on the wrong side of the edge.? If not then Zero the Z-axis and mark it's position then write some G-code so it moves back n forth several 100 times, only needs to be short moves. Make the last move go back to Zero.
If it doesn't return to the mark then you need to change the active Hi/Low in motor tuning for that Axis.-use common sense, if you lack it, there is no software to help that.
16-06-2020 #649
Thanks Dean, no I don’t think I ever did that test on the Z axis but I did on the other two. I’ll give it a go and see, but really wanted to finish this job!
I reduced the Velocity on z from 2.5m/min to 2m/min and the acceleration from 250 to 200 and ran the roughing pass again a little slower than before and it cut to the end without any trouble (although it is hard to tell if it lost any steps as it is only a roughing toolpath). But once it was done and had gone back to zero for the tool change it kept making little erratic movements again. Could this still be to do with buffering if it is stopped for a tool change? I videoed it for a few seconds this time, if you have the sound on you can here it making little jerky moves. This was at the tool change so no g-code to tell it to move and nothing changing on the DRO. I don’t get it?
https://youtu.be/m1vlkqPeVMM
16-06-2020 #650
No Joe that's definitely not the buffer...Lol
It looks very much like a noise issue.? But knowing your setup and the fact spindle isn't running I'd be surprised if it was.! . . . . Have you grounded the chassis.?
I'd be going over all the wire connections in the control box first looking for loose connections or stray wires. Also If you have any plug connections like DIN sockets on motor cables I'd check them out as well, in fact, chop them off and throw them in the bin as they are a pain in the arse.!!-use common sense, if you lack it, there is no software to help that.
There are currently 24 users browsing this thread. (0 members and 24 guests)
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
