    D.C.'s Avatar
    Surely that's because they're discussing using it for making bearing surfaces, where clearly the dimensional tolerances are critical. Does it really matter here if it shrinks a bit...
    I'm not sure tbh, if you have a solid, shrunken lump inside of a steel box surely most of the vibration will just stay in the steel and not pass into the EG, the steel beam would also deform like normal steel until it made cotact with the EG beam?
    This is why someone really needs to part with some cash and do some directly comparable real world tests...
  2. Click image for larger version.
Name:	Revised 80x80x3 frame.jpg
    Revised 80x80x3 SHS frame - brings the cost down quite a bit. 6mm plate and/or welded connections...
  3. Just been going through the whole of your thread, its given me some good info for my design/build....where are you at with it now?
  1. BUILD LOG: 3 Axis Router
  4. 3 axis cnc/router bed
