Page 23 of 66 FirstFirst ... 13212223242533 ... LastLast
  1. Thanks for the tips!
  2. #222
    Joe I did not have any shrink problems at the ends on mine but do put the effort in to stop any leaks you will be surprised how easy it is to get one, a small bead of silicone is the key
  4. #223
    Lives in Plymouth, United Kingdom. Last Activity: 3 Hours Ago Has a total post count of 1,747. Received thanks 298 times, giving thanks to others 11 times.
    I sealed my moats by running a small amount of epoxy along the gap first. Small amount and it doesn't run through but will cure in the gap and stop it leaking when the full depth goes in a day or two later.
  5. The Following User Says Thank You to Neale For This Useful Post:
  6. #224
    been looking at nema 34 stepper motors online,,,,,would they be suitable ?,,,,,i plan to be machining sheet material like mdf,,,melamine,,,oak and ash ect.. also i see the motors are avalable with differant holding torque......would the higher values be advisable.
  7. #225
    Quote Originally Posted by voyager1972 View Post
    It is impossible to say what size of motors you require without giving details re your machine. It might be a good idea to start your own build log to keep all the questions in one place.
  8. The Following 2 Users Say Thank You to Clive S For This Useful Post:
  9. #226
    Clives 100% correct but it's also 95% chance they won't be suitable for few reasons. First reason high chance they will be high inductance motors which mean you'll need expensive high voltage drives.
    Second reason is they'll be all wrong for your machine unless large or heavy load to move.
    Jo be careful you have enough epoxy because it's proper ball ache if you run short. However I know 1ltr should be enough for machine your size so shouldn't have any trouble.
    Really make sure you seal it well because it's amazing how epoxy finds leaks and they don't always appear instantly so keep checking and be ready to make repairs. Putty is handy stuff to seal quickly.
  10. The Following User Says Thank You to JAZZCNC For This Useful Post:
  11. Click image for larger version.
    Surface ground and scored with sandpaper. Dams almost complete... Click image for larger version.
  12. #228
    Looking good Joe....looking forward to seeing the pour!
    Neil...
    Build log...here
  13. Quote Originally Posted by njhussey View Post
    Me too. Bought some silicone sealant and found an oil radiator donor! Nearly ready...
  14. #230
    Quote Originally Posted by JoeHarris View Post
    What's the oil radiator donating?
    Neil...
    Build log...here
  1. BUILD LOG: 3 Axis Router
  4. 3 axis cnc/router bed
