  1. In the interests of completeness of my build log and in the hope that it may help demystify building your own power supply here are a couple of videos of my power supply build. Although it is obvious to me, I will point this out for any with less common sense - working with electricity, particularly mains can be very dangerous. If you want to build your own psu then you can take it from me, a totally amateur, that it is perfectly doable if you ask the right people the right questions. Please post your design and invite comment before embarking on a project like this. You need to consider what the right transformer, rectifier, capacitors and fuse will be before starting and do your research, because connecting it all up wrong will be disastrous. Thanks to Dean, Clive and Barry in particular (as always) for the tips and guidance. Ps any comments on my very basic explanation in the second video (about 12mins in) will be gratefully received although I except from the outset that it is basic!!
    https://youtu.be/4OoQQg76ar4
    https://youtu.be/WISDqx-e23M
  2. The Following User Says Thank You to JoeHarris For This Useful Post:
  1. BUILD LOG: 3 Axis Router
  4. 3 axis cnc/router bed
