I'm after a reasonably priced ball nose mill suitable for cutting foam with a cutting length of at least 175mm in the UK
The only ones I have found are the tools from Frog from the US
(http://3dcutting.com/products/frogtools)
Anyone know any good sources in the UK?
Thanks,
James
04-05-2012 #2
Thanks chip,
Those cutters are close, but still about half the length I need, have enquired on the custom option...
I have searched for that thread, but can't seem to see it, can anyone point me to it?
Thanks,
JamesLast edited by jamezwarner; 04-05-2012 at 02:34 PM.
04-05-2012 #3
I remember seeing some on eBay some time ago...
What diameter do you need? Perhaps extending an existing cutter is an option. When I needed a long 1/2" ballnose cutter for MDF I just used a cheap router cutter with a 1/4" shank and made an extension with it using 12mm steel bar. Then hardened it for good measure. I chose 12mm steel bar as being a slightly lower diameter than the cutter the extension cannot interfere with what you're cutting.
05-05-2012 #4
I use long 6mm or 8mm twist drills reground (by eye/hand) to a round end. Works for me.
Alan D.
09-05-2012 #5
High Density Foam? Best result I had was with a Burr bit :s or maybe I just got the whole spindle speed/feed rate wrong :)
10-05-2012 #6
Aha, spindle speed? I don't know - I use a cheap 240volt router run at 100volts. It lasts for ever in that mode. A slow(ish) speed sometimes helps prevent the foam sticking to the bit with heat if you are cutting deep. That varies with the foam density and composition, of course.
Alan D.
RFQ: 7mm Ball on 4mm bar 15mm long (as 1 part) x 50
By Fletchirwin in forum Projects, Jobs & RequestsReplies: 0Last Post: 23-01-2014, 10:00 PM -
Extra long end mills for milling foam
By gavztheouch in forum Marketplace DiscussionReplies: 6Last Post: 22-01-2014, 09:01 PM -
WANTED: 3mm Ball nose bit please
By Fivetide in forum Items WantedReplies: 6Last Post: 12-12-2012, 05:06 PM -
1.5mm ball end mill supplier in the uk
By luke11cnc in forum Marketplace DiscussionReplies: 9Last Post: 21-01-2012, 08:25 PM -
Mini Lathe - chuck key, long nose type sourceable?
By HankMcSpank in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 19-10-2009, 01:41 PM
