Aha, spindle speed? I don't know - I use a cheap 240volt router run at 100volts. It lasts for ever in that mode. A slow(ish) speed sometimes helps prevent the foam sticking to the bit with heat if you are cutting deep. That varies with the foam density and composition, of course.
Alan D.
RFQ: 7mm Ball on 4mm bar 15mm long (as 1 part) x 50
By Fletchirwin in forum Projects, Jobs & RequestsReplies: 0Last Post: 23-01-2014, 10:00 PM -
Extra long end mills for milling foam
By gavztheouch in forum Marketplace DiscussionReplies: 6Last Post: 22-01-2014, 09:01 PM -
WANTED: 3mm Ball nose bit please
By Fivetide in forum Items WantedReplies: 6Last Post: 12-12-2012, 05:06 PM -
1.5mm ball end mill supplier in the uk
By luke11cnc in forum Marketplace DiscussionReplies: 9Last Post: 21-01-2012, 08:25 PM -
Mini Lathe - chuck key, long nose type sourceable?
By HankMcSpank in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 19-10-2009, 01:41 PM
