Thread: Sieg SX2 Plus build
Laurent,
I can see your point but in the case of the SX2 where the nut would be very close to the gibs I don't think this will apply, there have been literally thousands of CNC mills built or converted of the Bridgeport type where the nut block is secured to the front of the quill which would have the same effect but in a front to back application instaed of a side to side.
In fact my big Beaver mill has exactly the same layout on the head and the Y movement is even worse as the ball screw hangs off one side, only the X has a central screw.John S -
22-06-2012 #2
Hi John,
OK, I beleive you... ;-)
I like your lubricating system! Nice!
Laurent
Sieg - KX1
By ptjw7uk in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 31-07-2016, 11:25 AM -
FOR SALE: Sieg x3
By andris in forum Items For SaleReplies: 4Last Post: 25-02-2014, 06:32 PM -
Sieg KX3
By gently in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 10-09-2011, 11:42 AM -
Sieg X3 backlash...
By Vikash in forum General DiscussionReplies: 0Last Post: 20-10-2010, 02:51 PM -
Sieg SX2 in the UK?
By TheChunk in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 13-09-2010, 03:00 PM
