Quote Originally Posted by russell View Post
Yes, I've seen that done. It depends what you're using the machine for but I would be worried about cutting forces moving the head up and down. How well do you find it works? What material are you cutting?
Russell.
Hi Russell. It seems to be accurate to at least 0.1mm as far as I can tell, probably nearer 0.05mm. I have a counterweight on the head and the gib reasonably tight.
I mainly cut aluminium but had a play with some 304SS over the weekend. Here's a couple of pics (if I can work out how to upload them.......)
Name:	aluminium mould.jpg
ID:	6228Click image for larger version.
Cutting the stainless was painfully slow (10mm/min 1mm DOC with a 2.5mm slot drill) but that was to prevent heat buildup (no coolant and just HSS bits). I've definitely got a lot to learn and loads of tools etc to save up for!
I'm still on the original leadscrews/nuts and have the DIYCNC system 4 with 3.1Nm steppers driving direct. (I won't get the max from these motors cos the system4 only gives 3A while the motors can take 4A.) I'll probably change this to a 2:1 reduction even if I don't eventually move to ballscrews.
I'm trying to convince myself I can make a bit of pocket money from it before spending much more!
Ian
