Yes I have been using it to cut 18mm birch ply wood and I see no reason as to why it would not cut 25mm. The router is a 2hp hand held bosch type. So I would recommend upgrading to a much larger spindle and z-axis, this means you could cut through the 25mm a lot faster.
Do you have an example of the parts you would be cutting?
How you had any experience with CNC routing before?
Gav
07-06-2012 #2
thanks, never used a CNC before. it would be used to cut circular stage tops in sectors, ie a 4m diameter stage would be made up in 16 wedge shaped pieces, a bigger stage for example a 9m dia. would be made up of an inner circle 5m dia. from 16 sectors and an outer ring around them of 32 sectors to make the 9m. all in 25mm far eastern plywood. can any router head be fixed to this unit then. does it have the suction bed that hold the sheets down?
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
BUILD LOG: 3 Axis CNC router
By JoeHarris in forum DIY Router Build LogsReplies: 658Last Post: 21-06-2020, 10:41 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
