Thread: CNC Newbie
Ok so your a special needs case. .
At 3x2 mtrs you will always struggle cost wise to find a decent but sensible money machine and the AXYZ pacer machines you have seen will be stupid money or knackerd if under 5K, esp has you don't see many in Uk either.
With a machine this size, apart from some of the technical aspects of building the machine IE: whether use ballscrews, rack and pinion etc, one of the bigger problems or issues's is holding the work while cutting.?
With the type of work and materials you'll probaly use then chances are you'll need a good vacuum bed to hold down large sheets. If these sheets get cut thru IE: several pieces cutout from one sheet or lots of holes drilled then the vacuum system needs to be very very good.!!! . . . Very very good = very very expensive.!
Unfortunatly when going large it does or can become expensive by the very nature of the technical aspects of building a machine this size. IE bigger more expensive components etc and if your needs are special like needing vacuum beds then it does get really expensive.!!
This is why often the only way folks like yourself running 1 man & Mrs business's look to DIY because the same machine bought from a CNC manufacturer to fit there needs is muchO spondulaks and way out there budget.
How much wonga you looking or expecting/prepared to spend. . . OR better still let me say this.!!
Even if you DIY and are not prepared to spend in the 3-4K region absolute minimum then don't bother because you'll be wasting good time and money.
4-5K would be a realistic figure for capable reliable machine with some nice trimmings that you could confidently run a business on.!
Sounds a lot of dosh but the same machine bought would be 10-15K or more.!!
Only you can decide if the time needed to invest DIY building is worth the saving or whether to bite the bullet and suck upto the bank manger.?????
If buying like I say run it buy us here first has there's lots of rubbish out there, Esp on Ebay, that will look ok to a first timer with the horn on for CNC.!! There often sold by twats full of bullshit waiting and willing to rip off new first time users as well.!!!
Edit: You could always look to importing one of the chinese built machines but I think you'll still be in the 10K region for a machine this size after import duty's, shipping etc.?Last edited by JAZZCNC; 11-05-2012 at 08:45 AM.
11-05-2012 #2
I only mention Pacer because thats probably the only name I've seen about. There was one local that was selling for 5.5k and had vaccum bed and was serviced 6 months ago. As the guy was local, any pointers I needed he would help. He was upgrading his machine and didn't have the space for the one he was selling.
Obviously the cheaper the better but I do understand what your saying about you get what you pay for.
Reason for getting one is that were wanting to expand, and we've probably passed about 15k to out sourcing this last 12 months, which the money we're saving on outsourcing would warrant buying one. But at the same time couldn't warrant spending 20k plus on one.
11-05-2012 #3
11-05-2012 #4
I was going to but we're currently looking at a new unit and don't have the room to store it at the mo. Now its gone :(
We outsource flat cut letters, built up letters, sign trays and shaped signs out of aluminium composite, mdf and acrylic.
NEW MEMBER: Another newbie
By Moddsey in forum New Member IntroductionsReplies: 0Last Post: 27-05-2014, 11:08 AM -
newbie needs help
By pauley555 in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 05-07-2012, 09:48 PM -
NEW MEMBER: newbie
By stevedemicoli in forum New Member IntroductionsReplies: 5Last Post: 31-03-2012, 10:12 AM -
NEW MEMBER: Newbie here
By Mr Tim in forum New Member IntroductionsReplies: 0Last Post: 23-08-2011, 08:50 PM -
NEW MEMBER: Newbie Here (sorry)
By graysclassics in forum New Member IntroductionsReplies: 0Last Post: 04-07-2011, 09:44 AM
