Thread: 14mm ballscrew + nut for VMC260
04-06-2012 #11
i would go to at least a 4 or 5mm pitch and change the gearing to retain the ratio. it's possible to use a flanged nut and mount it from one side, as the original is mounted this way. I've replaced a full set of ballscrews on the 260 and had a nightmare to get the nuts sorted. I'm currently helping a friend replace a 240 x axis ballscrew with a standard flanged nut and all looks good so far.
04-06-2012 #12
the reason i say go for a larger pitch (5mm), is you get a far stronger ballscrew which will give probably 5 times the life of the 2.5mm pitch screw. These boxford ballscrews are a common fail point, and are just not upto the job.
Boxford vmc260 to mach3 conversion
By jamesgates1000 in forum Boxford Vertical MillsReplies: 22Last Post: 30-01-2020, 11:47 PM -
FOR SALE: ArcEuroTrade 650Ncm 14mm Shaft stepper motor
By m_c in forum Items For SaleReplies: 0Last Post: 13-04-2014, 02:19 PM -
cost of converting vmc260 and tcl125 to mach 3
By franky in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 12-01-2014, 10:25 PM -
16 tooth pulley HTD5 15mm on a 14mm shaft
By dsc in forum Belt Drive, Pulleys & TimingReplies: 6Last Post: 07-06-2013, 11:51 AM -
FOR SALE: Boxford VMC260
By pdl in forum Items For SaleReplies: 1Last Post: 17-11-2011, 10:28 PM
