Saw this posted on Hackaday, thought it worth mentioning here...
Self Replicating Milling Machine
Not sure I'm qualified to have any sort of opinion but workpiece access is a bit restricted, and I can imagine any flex or vibration having odd effects due to the structure.
- Dave
17-05-2012 #2
If using the X2 mill head and column why not use the whole thing? I don't like the idea of using the rack and pinion for the Z. It must give no end of problems with the backlash.
Russell
01-03-2014 #3
Looking back at this and reading the blog -
"This chatter eventually became so serious that some screws which I had failed to tighten fully began to back themselves out."
:-O
01-03-2014 #4
I don't get the "self replicate" bit. Not the spindle - not the slides nor the carriages. Not the racks - not the screws - not even the square bar - not the sweet FA apart from maybe the odd bracket.
01-03-2014 #5
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Vac - clamp looks interesting and cheap what do you think?
By Fivetide in forum Machine DiscussionReplies: 3Last Post: 10-10-2012, 09:06 AM -
Interesting DIY findings from Canada
By Iwant1 in forum General DiscussionReplies: 5Last Post: 10-09-2012, 09:59 PM -
Small Mill very early design stage
By leadinglights in forum Milling Machines, Builds & ConversionsReplies: 29Last Post: 15-06-2010, 01:05 AM -
Interesting CNC image BLOG ..
By emilvv in forum General DiscussionReplies: 0Last Post: 20-07-2009, 08:29 AM
