Thread: converting pdf to cam?
Antonio's clocks are in a pdf format. How would you convert this into something that you could generate g code from?
BruceThe more I know, I know, I know the less. (John Owen)
18-05-2012 #2
Bruce,
Inkscape can open PDFs and save as DXF, but I've had better results with Vectric Cut2D which can open pdfs directly,
Nathan
18-05-2012 #3
Thanks Nathan. i will give it a try
19-05-2012 #4
I tried cut 2d but it seemed to load every page of the pdf at once.
Just loaded inkscape and it worked a treat. You can select which page to load and then save them to dxf. Thanks NathanThe more I know, I know, I know the less. (John Owen)
21-05-2012 #5
Better Better DXF output is worth plugging in to Inkscape:
http://tim.cexx.org/?p=590
21-05-2012 #6
thanks musht. I have added the files.
23-05-2012 #7
This is usefull information thanks Nathan! I'll have a look at Inkscape as I've got lots of PDF's I want to convert to DXF's.
28-02-2014 #8
You can do that by advanced Acrobat reader.
They av options to convert file in whatever your format.
There are currently 27 users browsing this thread. (0 members and 27 guests)
Hi help converting emco f1
By Ecu-master in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 30-03-2014, 12:24 PM -
Converting sketchup to dxf
By motoxy in forum SketchupReplies: 3Last Post: 08-07-2012, 12:04 PM -
Converting Cardboard to DXF
By Yow Ling in forum General DiscussionReplies: 12Last Post: 15-11-2010, 10:18 AM -
NEW MEMBER: CNC converting in Sweden
By hubben in forum New Member IntroductionsReplies: 1Last Post: 28-09-2010, 06:16 PM
