Thread: converting pdf to cam?
Bruce,
Inkscape can open PDFs and save as DXF, but I've had better results with Vectric Cut2D which can open pdfs directly,
Nathan
18-05-2012 #2
Thanks Nathan. i will give it a try
The more I know, I know, I know the less. (John Owen)
19-05-2012 #3
I tried cut 2d but it seemed to load every page of the pdf at once.
Just loaded inkscape and it worked a treat. You can select which page to load and then save them to dxf. Thanks NathanThe more I know, I know, I know the less. (John Owen)
21-05-2012 #4
Better Better DXF output is worth plugging in to Inkscape:
http://tim.cexx.org/?p=590
Hi help converting emco f1
By Ecu-master in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 30-03-2014, 12:24 PM -
Converting sketchup to dxf
By motoxy in forum SketchupReplies: 3Last Post: 08-07-2012, 12:04 PM -
Converting Cardboard to DXF
By Yow Ling in forum General DiscussionReplies: 12Last Post: 15-11-2010, 10:18 AM -
NEW MEMBER: CNC converting in Sweden
By hubben in forum New Member IntroductionsReplies: 1Last Post: 28-09-2010, 06:16 PM
