    On a more helpful note you mention home location and tool changing - don't let one dictate the other as you can set a PARK position at any arbitrary point you want. Mach3 2010 screenset has this built in or you can add the feature to the standard screen if I remember correctly.
    Agreed and just to add to this 2010 screen set actually has a TC (tool change) position and a Park position. In practice you'll change tools anywhere you feel suits you best and it probably won't be in one set location.
    Many don't realise you can actually jog away to any point to change tools so often you'll just jog closest location to you from work piece and change tool there. Running to the other end of even a medium size machine to change tools soon becomes tiresome, so nearer to the Work location the better.
    This fits and brings nicely to placing work piece on the table.? Again on medium to large routers you'll often be cutting pieces much smaller than the table size and it's tempting to always locate in same place which is easy to reach.!! . . . This is not good for the machine as it tends to wear screws and rails etc in one place more than another so spread the work around the table. This is when you'll want to jog to closest location to workpiece rather than run to other end of machine for each tool change.
  1. FOR SALE: Emco mill 50 cnc mill like Denford Triac
