Page 18 of 29 FirstFirst ... 8161718192028 ... LastLast
  1. #171
    Many thanks Clive
    I am searching around in the hope of finding them a bit cheaper but at least i am on the right track!
    You might find it cheaper to get multiple smaller caps, I got 4 x 4700uF ones for a few pounds each, just means more connections to make...
    Neil...
    Build log...here
  3. #173
    Also... what sort / size cable do people generally use for wiring coming from the psu to the stepper drives and wiring the power elements of the estop circuits bearing in mind I am using the CSMIO from cslabs so its all 24v in relation to the motion controller except the mains in
    Just trying to get an idea of whats best to order in bulk
  4. #174
    Quote Originally Posted by fvfdrums View Post
    You could use cat5 flexi cable or a screened cable for all the switches and limits, Estop etc. 1.5mm CY 4 core for the steppers (don't forget to ground to a star point at the driver end) and a bit of 2 core from the 24V power supply to the BOB.
  5. The Following User Says Thank You to Clive S For This Useful Post:
  6. #175
    You want Tri rated for general single wire runs for power to steppers, relays etc like this. http://www.csecables.com/acatalog/Tr...l#aTri_2d0_2d5
    For signal cables you want Shielded CY cables or like Clive says you can use twisted pair Cat5 but only use inside control panel not running to limits etc on machine as it's not really flexible enough. I tend to use Cat5 in box as theres less wires and one cable will provide for 2 drives.
    http://www.csecables.com/acatalog/CY-Cable.html
    Bear in mind the Csmio doesn't provide voltage from the I/O you have to feed it 24V +/- to each I/O so you'll need plenty of connections on the 24V rail or do some jumpering. Suggest you get some Din rail terminals with Jumper bars to create one Multi connector.
  7. #176
    Thanks Clive and Dean.
    That tri rated cable what size am I am looking at for the stepper power feeds?
  8. #177
    Well 0.5mm/2 would be ok on Max amp rating given most motors are rated around 4-5A but 0.75mm/2 will give plenty of safety margin if you'd prefer OTT. I think the Tri rated cable is safe to around 600Vdc so you no worries here.!!
  9. #178
    Yes quite correct I should have said cat5 flexi as in the patch cable type. (although you can buy flexi by the roll). Clive
  10. #179
    Aliexpress is your friend for cheap capacitors, and just about anything really:
    http://www.aliexpress.com/wholesale?...t=10000uf+100v
    You need to be wary of fakes - I got these as they were the cheapest at the time and they're fine. On the lower end of the tolerance but that's not a big deal for what we're doing.
  11. #180
    [Tried to edit previous post to add this, but kept getting 'message too short' error]
    This is how I've been using the capacitors:
    It keeps things reasonably neat.
  1. FOR SALE: Emco mill 50 cnc mill like Denford Triac
