Thread: New CNC Mill on the horizon
18-03-2015 #211
Thanks for all that info guys very helpful. I can just about get away with2 m4 grub screws on these pulleys so that's the way I'll go.
Half finished up one side cover just waiting on some bits to arrive. I figured if I didn't do it now once the machine was running I would probably keep putting it off!
18-03-2015 #212
I was looking at a way of protecting the ballscrew and was thinking of C section Ali but couldn't see how I was going to put the brush on the rail side to seal the gap. How are you doing it as I can't see a brush so I guess chips etc could still get in there?
18-03-2015 #213
As I mentioned it's half finished. If you look there is a brush on the outside edge, I did try a 2" brush from one side but it was too much so opted for 2 1" brushes. The other just sits off from the bearing rails on the inside of the gantry so the two pretty much meet in the middle.
18-03-2015 #214
So you did....I must have glossed over that bit! How are you fixing it by the rails? Looking forward to seeing it finished...
18-03-2015 #215
The brush sections fit neatly under the bearings with enough clearance for some countersunk m5 screws to hold it down along the full run. Just haven't got round to that yet.
18-03-2015 #216
Btw tool station are pretty good price wise on these brushes.
18-03-2015 #217
Where did you get your brush strip from, how thick is it?
I wasn't quick enough!!!Last edited by njhussey; 18-03-2015 at 09:42 PM.
20-03-2015 #218
Right we are wiring up the psu. Transformer wired correctly giving 52 Vac. Connected to the Bridge rec at correct terminals. Output from the rectifier on the dc terminals is 45v ?? Shouldn't this be 70ish? Do we have a broken rectifier?
20-03-2015 #219
20-03-2015 #220
Thanks Jonathan,
so we have now connected the caps up to the BR, on powering up to check what voltage we were getting instead of even getting there we got a huge amount of humming and some extreme heat through the negative cable coming from the BR so immediately turned it off.
any ideas what could be going on / we are doing wrong?
we have checked that it is definitely the +ve of the BR going to the +ve on the caps and the same for the -ve.
does there need to be a load on the PSU before we power it up?
There are currently 24 users browsing this thread. (0 members and 24 guests)
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM
