Thread: New CNC Mill on the horizon
If you have been lurking long enough you will have probably seen my dislike of round rail/bearings and complete louthing of unsupported rail.!! . . IMO really is no comparison between round rail and profile rail.! Profile rail makes the difference between DIY machine and Pro machine that will out last the machine and out perform round rail by magnitude of 10X.
To me if your serious enough to invest couple of grand and several months of hard graft then the extra cost is just not worth skimping on and like Jonathan says if you've waited 5yrs then don't spoil the broth for a pinch of salt and wait untill you can afford them.
Regards size then 15mm will more than handle the load but I find 20mm is the better option due to bearing size being slightly larger offering better support and easier mounting. 25mm is just over kill unless really large/heavy machine and waste of money plus has well has being inefficeint and stressing the motors more.
18-05-2012 #2
Jazz,
To be fair I expected that comment and yes I do agree that profile is the way to go just got to find a good supplier!
Any suggestions?
18-05-2012 #3
18-05-2012 #4
Hi fvfdrums,
When I made my machine a few years ago I bought profile rails from this place on ebay. For example:
http://www.ebay.co.uk/itm/THK-SSR20-...item4165411fab
They are second hand parts, so you take a chance, but I ordered a pair at 700mm (Y) and a pair at 300mm (Z). 700mm was about £140 for pair of rails and 4 blocks, and 300mm was around £80 for pair of rails and 4 blocks. Vaguely remember paying import tax on one of these orders. They had a very smooth action and work very well on my machine although I only really cut plywood, liteply, and balsa.
19-05-2012 #5
Forgot to mention, those are all rails/blocks with 4 rows of balls which is what you want since their load rating is equal in all directions and the moment load is greater. Two rows is still fine if they're quite big and clearly still far superior to supported round rails.
I better keep them locked up else they will be!
19-05-2012 #6
16-12-2012 #7
Agree with jazz about the X-screw - RM2005 wont help. The problem is the pitch is half what you get with RM1610, so you have to spin the screw twice as fast to get a given feedrate. Going from 16mm diameter to 20mm doesn't make the critical speed twice as much (only 25% more) so you actually end up worse.
RM1610, critical speed - 1460rpm => 1460*10=14.6m/min
RM2005, critical speed - 1825rpm => 1825*5=9.1m/min
The feedrate with either screw is plenty, but since 20mm is more expensive and in addition to the above a 20mm screw requires significantly more torque than 16mm, so you only gain stiffness/lifetime which on a router like is completely negligible since the 16mm screw is strong enough and will last for many years.
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM
