Thread: New CNC Mill on the horizon
02-03-2014 #11
Originally I was going to have a load of parts cut for me but I as I was not sure my Mill was up to the job, or the long runs needed 400mm plus in some cases however I sort of took the bull by the horns in the end when i couldn't get them all done and bought some good measuring devices which makes all the difference.
Also spending time to get the correct cutters, feed speeds, and DOC are important. Luckily I used to run a large CNC lathe and had a load of high quality end mills left from this which just turn aluminium into lovely little chips so its not so much a problem but like I said the play in the spindle when extended on the mill is not good so trying to get the workpiece as close to the start point of the mill was important. After that is was surprisingly satisfying :)
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM
