Thread: New CNC Mill on the horizon
03-02-2015 #11
If you identify the bend location you can make a fair job of straightening these screws using a vice and 3 blocks of wood. You'll be surprised how much bend the screws will tolerate before becoming a problem. Obviously any bend will have a little impact on the life of the screw/nut but IME even moderate bends won't affect machine performance to much and last years without any problems. I doubt you'd still have machine before it became a problem and when it does you'll be ready for changes and upgrades.
Regards the BK bearings then check the bearings are not in wrong way around which often happens. I strip every bearing to clean/re-grease then shim and every other one the bearings are in wrong way around.
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM
