Thread: New CNC Mill on the horizon
23-03-2015 #11
Problem solved, one wire going into a din connector was clamped on the insulation and not connecting, after that works fine so thanks.
Finally..... The relay outputs from the csmio - to control the spindle forward control from Mach should it just be wired from DCM on huanyang inv to pin 25 and pin 12 to For? That's for relay output 4 I'm hoping? I've got the analog hooked up fine just can't get it to switch on. I've set the parameters as well so it's not manual control pd001&2 I think (not in front of the machine right now)
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM
