    When you say check the disable relays do you mean put a tick in the box or check it's not ticked?
    The csmio manual suggested it should be unticked.
    However tried it both ways and it still doesn't work.
    I have 24v across DCM and For at the inverter. And 24v at pins 25/12
    Output 4 light comes on but no action. Have I missed something in the inverter settings :/
    Sorry bit lost now
    Ye sorry my fault worded it wrong should have said make sure un-ticked.
    Sorry about this but I know what your problem is but must have had brain failure.!!! . . . . . . In ports n pins set the out put your using for spindle to Pin 4 not pin 12.!! . . . . It's a cock up in the manual and to make it worse I was the one who told CSlabs about it so should have known better.!!
    For instance if you set M3 in spindle control to output #1 then go into outputs and set output #1 to pin4.
  1. FOR SALE: Emco mill 50 cnc mill like Denford Triac
