Thread: New CNC Mill on the horizon
Personally i just use the Limit overide inside Mach. But if you want an override then just wire a Momentry button in the circuit (don't use a Switch). Only time i use an Override button is if the Limits are wired in the Safety circuit and knockout Power Etc Which I don't do any more for limits.
Yes but not yet.! Run it slowly for a while and tweak alignment of screws. You'll be surprised how much just little missalignment can make to how machine runs and sounds. Then if it doesn't go away then think about stripping down after a few weeks when things have settled down.
If 10mm pitch screws and drive Micro stepping is 1600 then yes 160 is correct. Safe velocity for testing would be 4 or 5000mm/min with Accelleration of 500-600. With the aim of reaching around 10,000mm/min and 1000-12000s.
Homing is slower and will be a percentage of the Velocity which is set in Homing & limits. Faster you home the less accurate the repeatabilty. 20% is a good figure when at 10mtr/min.
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM
