Thread: Plasma Attempt #2
Forgot to say, 0.0022kgm^2 will add about 0.45Nm to the stepper torque requirement - angular acceleration of shaft is 4*pig/0.6. So torque=4*pig/0.6*0.0022=0.45Nm. So there goes your 2* factor of safety!
If instead of the tube you used 12mm steel bar it's only 0.0082Nm added, which is about the same torque as a 24T HTD pulley will require. Critical speed of 12mm bar is fine, but to avoid needless vibration you could pop a bearing in the centre to support it.
Those powers of 4 really do give some surprising results.Last edited by Jonathan; 19-05-2012 at 10:04 PM.
ok, first attempt using sketchup 8
By deannos in forum Gantry/Router Machines & BuildingReplies: 89Last Post: 25-08-2012, 03:00 PM -
BUILD LOG: My first attempt.... 8 x 4
By trounce in forum DIY Router Build LogsReplies: 0Last Post: 18-10-2011, 11:31 AM -
BUILD LOG: My First Attempt Of A CNC
By AdCNC in forum DIY Router Build LogsReplies: 61Last Post: 21-10-2010, 03:55 PM -
help please with first attempt
By phill05 in forum Machine DiscussionReplies: 13Last Post: 01-06-2010, 05:42 PM -
FeatureCam - first attempt
By HiltonSteve in forum CAD & CAM SoftwareReplies: 0Last Post: 01-09-2009, 07:46 PM
