  1. #12
    Progress...
    This is the assembly that connects one end of the 4" box section X axis gantry to the 30mm linear rail Y axis. There is a 2mm deep cut out on the front that is a good fit on the box section.
    There is a plate welded half an inch up inside the box section with a big iron nut in the middle so I can pull the box section firmly into the groove on this plate and hold everything nice and square with one M8 bolt.
    This assembly drives the 15mm tooth belt for the X. To be clever I put the top of the belt inside the box section and the bottom about 1.5mm below it.
    Have I made a plasma dust conveyor belt that will pump crut in to the box section?
ID:	6094   Click image for larger version.
  1. ok, first attempt using sketchup 8
    By deannos in forum Gantry/Router Machines & Building
    Last Post: 25-08-2012, 03:00 PM
  2. BUILD LOG: My first attempt.... 8 x 4
    By trounce in forum DIY Router Build Logs
    Last Post: 18-10-2011, 11:31 AM
  3. BUILD LOG: My First Attempt Of A CNC
    By AdCNC in forum DIY Router Build Logs
    Last Post: 21-10-2010, 03:55 PM
  4. help please with first attempt
    By phill05 in forum Machine Discussion
    Last Post: 01-06-2010, 05:42 PM
  5. FeatureCam - first attempt
    By HiltonSteve in forum CAD & CAM Software
    Last Post: 01-09-2009, 07:46 PM
