    Rob
    Do you have a sketch/drawing of your cnc plasma cutter?
    glad all the maths is out the way
    James
    Quote Originally Posted by luke11cnc View Post
    Well, yes, sort of, my drawings are rarely illuminating though
    Here's the bit I made today.
    I have to keep the cutter holder light because it's a dead weight that needs accelerating. I got it down to one piece of aluminium channel, the Hiwin bearing is the X axis, the 8mm linear bushings are the Z. The sticky out arm flips a roller microswitch so I have time to brake before the head slams into it's home stop. A sort of early warning device.
    A little Maxon rare earth motor with an epicyclic box raises and lowers the head (God bless ebay) with optical stops to set the cut and pierce heights.
    Bill, I think the key to long gantry plasma is to make everything adjustable so you can pull it straight and level when it's all together. I let you know if that is a good idea or a crap idea later
  1. ok, first attempt using sketchup 8
    By deannos in forum Gantry/Router Machines & Building
    Last Post: 25-08-2012, 03:00 PM
  2. BUILD LOG: My first attempt.... 8 x 4
    By trounce in forum DIY Router Build Logs
    Last Post: 18-10-2011, 11:31 AM
  3. BUILD LOG: My First Attempt Of A CNC
    By AdCNC in forum DIY Router Build Logs
    Last Post: 21-10-2010, 03:55 PM
  4. help please with first attempt
    By phill05 in forum Machine Discussion
    Last Post: 01-06-2010, 05:42 PM
  5. FeatureCam - first attempt
    By HiltonSteve in forum CAD & CAM Software
    Last Post: 01-09-2009, 07:46 PM
