12-07-2012 #10
Just read through this, and wanted to point out some unfair comments.
99.9% of issues with Windows "interrupting" Mach3 are power saving features, which can easily be disabled in most cases. Often they can be disabled from the bios, and may not be Windows issues at all.
Mach3 actually controls Windows to a certain extent, to provide accurate timing. And because it's a buffered system, "real time" is not really an issue. Sure, it may prevent you from doing some things that Linux can do, but there are no timing errors as you claim.No matter how much you disable things in Windows, remove programs or whatever fundamentally Mach3 is not real time so timing errors will exist.
If you want to play that game, Mach3 will automatically set your steps/unit without entering anything but a measured distance. You don't even need to know what components your machine uses.
'But I'm not a computer geek and it takes twenty thousand years to set up' I hear you cry! It really doesn't - the installation and setup process which apparently is such a huge barrier to many, is quicker, easier and more intuitive than windows/mach3. Owning a CNC machine makes you a geek to start with so it's too late for that anyway. In fact, the interface eliminates many human errors - I see countless problems from people setting the wrong value for steps/mm, whereas in linuxcnc, each pulley has its own textbox, meaning that you never have to do any fiddly arithmetic manually.
When Mach3 was originally developed (Mach3, not Mach1 or Mach2), 1.5Ghz PC's were state of the art. I run Mach3 on a $20 1Ghz PC with 512MB of RAM, and it runs great. I can buy PC's on Ebay all day long that will run Mach3 just fine for $50-$75. Including Windows XP
Another crucial disadvantage of Mach3, or rather windows is its inability to perform on low end computers - with some ebay sniping (gixen.com), it's possible to put together a low latency computer for less than £50, whereas with windows, if you want to get anywhere, you have to use a relatively expensive computer.
Really??? Maybe if your running Windows 95. From Windows 2K on, Windows is extremely stable, and will usually only crash for two reasons. Faulty hardware (usually memory), or bad software (very rare). I haven't seen Windows crash in well over 10 years.
LinuxCNC also boasts superior stability. Windows is known for its tendency to crash for no good reason on mid to low end computers ...................................
MAch3 can do helical arcs and threadmilling too.Look at what features come into play when a product is developed properly with the correct objective in mind - full support for helical arcs (allowing threadmilling).................................... ..............
Mach3 runs on Vista and Windows 7 as well as 2K and XP. It can't use the parallel port with Windows 8, though.Mach3 runs on windows 2000 and windows XP. Both are in steady decline with windows vista, 7 and 8 being forced out by Microsoft.
Apple users use whatever Apple feeds them. I can't see many apple users switching to Linux.Ubuntu is made to be incredibly user friendly and simple (it's marketed at Apple users amongst others).Last edited by Ger21; 12-07-2012 at 11:37 PM.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
how to smooth stl model, smooth curves out of straight lines
By chris in forum DeskProtoReplies: 4Last Post: 21-01-2014, 11:00 PM -
FOR SALE: Smooth Stepper board Plus C24 and C25 BOB
By AdCNC in forum Items For SaleReplies: 2Last Post: 11-09-2011, 09:56 PM -
FOR SALE: Smooth Stepper (UK)
By lateAtNight in forum Items For SaleReplies: 2Last Post: 24-06-2010, 10:19 PM -
better than smooth stepper
By Metalhead in forum Motor Drivers & ControllersReplies: 5Last Post: 21-06-2010, 06:43 PM
