Thread: Chinese Spindles
26-05-2012 #41
Ahh fair enough, would have linked to that myself if I'd known! For me 6000rpm is useless as the tools I use the vast majority of the time run at 9000-13000rpm.
Making an ATC system for 6000rpm is a lot less challenging since, to an extent, balancing is no longer an issue. Also you can use much bigger/stronger angular contact bearings than at 24krpm which makes the design much easier. Still not saying it's a straightforward project, but I'd consider it as even though that spindle is a good price compared to the rest it's still a lot of money to spend...
For motors you've got lots of options at 6000rpm. Most standard induction motors will overspeed quite a lot, so a 2-pole motor and a belt will give plenty of power and options. However they're rather heavy and bulky.
The motor I used on my micro lathe is actually ideal here:
[That's odd - it's dissapeared from www.hobbyking.com, it was called 'Turnigy 80-100-B 130Kv' ... I'll email to find out where it's gone, hope it's not discontinued. They're available elsewhere but more expensive. http://endless-sphere.com/forums/vie...?f=28&t=39779]
Being rated for 6.5kW (as if!) means you could probably afford to run it direct drive and still have plenty of power at 1000rpm, athough it would still be better to have two ratios. Probably 3:1 and 1:1.Last edited by Jonathan; 26-05-2012 at 01:21 PM. Reason: Added links
26-05-2012 #42
26-05-2012 #43
26-05-2012 #44
LMAO... now i trust your words because that is funny..
26-05-2012 #45
26-05-2012 #46
Oh what's this!
http://www.google.co.uk/url?sa=t&rct...6srckLwoIqwSSA
http://www.aysipu.com/English/produc...sh/product.asp
SPP1030-10-17F, 10,000rpm, $1000
Getting closer to our goal...Last edited by Jonathan; 26-05-2012 at 01:35 PM.
26-05-2012 #47Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
26-05-2012 #48
I'm looking at at least one maybe two of these BT30 atc spindles, so when you're looking at getting yours let me know. A better search may provide a better or cheaper product so don't rush into this one.
I also looked at the spindle with the motor, but i need to use 6k or less for mill use.
26-05-2012 #49
26-05-2012 #50
A lot of these places seem to have a quantity discount for 5. If there's one that does at least 12,000rpm then I could be persuaded, which would make 5 (Jazz, you*2, ricardoco, me). Bound to have to pay customs charges, but most seem to value them lower than the actual cost so that shouldn't be too bad.
I'll have a better look later as router is running at the moment...
The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
By Husky in forum Generic Chinese SpindlesReplies: 222Last Post: 22-01-2021, 06:54 PM -
motor power and chinese spindles power HELP
By DigiSoft in forum Spindles & Drive MotorsReplies: 5Last Post: 17-09-2013, 12:17 AM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM -
NEW MEMBER: Spindles
By Johnp in forum New Member IntroductionsReplies: 4Last Post: 28-06-2009, 11:46 AM
