Thread: Chinese Spindles
24-05-2012 #21
25-05-2012 #22
Ok well maybe im going down the wrong track, maybe i should have just asked if there was a suitable spindle that suited an atc conversion was not massive in size had a speed of > 6000 rpm but would be happy at 1000 rpm should the need arrise (lower speed not essential because not against using pulleys) but had a good amount of torque
25-05-2012 #23
Well not so much a wrong track has a potentialy expensive one with high percentage for disapointment unless well thought out.??
Like I say if it was relatively easy and CHEAP they would be available by now has there have been plenty of people asking about ATC over the years since affordable WC spindles arrived on the scene.!!
I'm sure it will happen sooner or later thou.??????????????
25-05-2012 #24
So what do you suggets then or should i throw it out there in a new thread...
25-05-2012 #25
Sorry hope you don't think I'm being negative or argumentative I'm really not just trying to be realistic.!!
I can't suggest anything more than I have already. If I had a cheap answer I'd be shouting about it.!!
All I know what your after with compact high torque and high rpm and a decent ATC setup hisn't cheap to buy or would imagine to DIY cheaply.
25-05-2012 #26
Money isnt really a problem to be fair, i just want the best value with what i spend, and if that means submitting designs to engineering companies to have the things custom made then so be it, on the other hand im not sure i want to spend £2000 when i cant help thinking there must be a cheaper way..... after all this forum is full of people with mills and routers isnt it
25-05-2012 #27
Yes I get what your saying and this is my point.! To do it correctly and be worth the trouble it won't be any cheaper I don't think. Custom made anything cost's money.!!
This is my take on it.!! . .The chinese WC spindles in there current format are not really suitable to ATC for both the spindle taper type and the fact they are high speed low torque motors.
To design one based on the current WC spindle will require much trial and error and at £180 pop and quality angular contact bearings etc you don't need to get it wrong many times to start building up the costs.! . . . . If you did manage it then IMO you would still have a less than ideal ATC setup.!
If moneys no object then go for it and I know I'll be watching with great interest.!
If you want an idea of the work involved in building a proper ATC spindle then checkout Henriks thread on cnczone and he still wasn't 100% happy with it when finished because it had 0.01-0.02mm runout.!! . . . He's bit of a perfectionist thou.!
http://www.cnczone.com/forums/vertic...roject-13.html
26-05-2012 #28
http://www.aliexpress.com/product-fm...olesalers.html
Use your own motor to suit,
The Following 2 Users Say Thank You to i2i For This Useful Post:
26-05-2012 #29
or
I have one of these planned to replace an old bridgeport styled milling head.
26-05-2012 #30
The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
By Husky in forum Generic Chinese SpindlesReplies: 222Last Post: 22-01-2021, 06:54 PM -
motor power and chinese spindles power HELP
By DigiSoft in forum Spindles & Drive MotorsReplies: 5Last Post: 17-09-2013, 12:17 AM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM -
NEW MEMBER: Spindles
By Johnp in forum New Member IntroductionsReplies: 4Last Post: 28-06-2009, 11:46 AM
