Thread: Chinese Spindles
21-06-2012 #111
22-06-2012 #112
well i've spent a few hours today pulling apart the J head on the first quatro, and it looks like i'll probably be stripping the quill and putting a new bt30 atc spindle into it to replace the R8 spindle. It would be a shame not to utilise the existing head and quill with it's bearings.
The design of this spindle will probably be longer that the design on other ones, so mine may well be a special.
22-06-2012 #113
Back to the trawling then....
HELLLLPPPP Im going round in circles here...lol
22-06-2012 #114
no reason why we can't keep going down this line, it just means my ones will be slightly different
23-06-2012 #115
28-06-2012 #116
News from my end, i'm having the existing spindles reground to match the 30 taper, when they're back i'll see if they do the job. If so i'm out guys, this will save me a fair bit so i have to try it.
16-08-2012 #117
Did you get anywhere with this?
I just spotted that the 6000rpm spindle from the same seller linked to earlier has 5% off and more interestingly someone's actually bought and reviewed it:
EN027# Spindle with synchronous belt for CNC milling BT30 ATC steel ball clamp+ disc spring+drawbar-in Machine Tool Spindle from Industry & Business on Aliexpress.com
'Fast delivery and nice spindle, but not the dimensions shown on the drawing on the listing. Diameter is 80mm above the flange and 85mm below it. It is in fact a SIPU model SPP8030-060-10F But still a BT30 ATC and 6000rpm so I am happy. :) FYI the timing pulley is a 45 tooth HTD5M and is 35mm wide Thanks'
Still too much to spend for me to only get 6000rpm...
16-08-2012 #118
got the spindles back from the grinder and a bt30 hoder rings quite well into them. I'm in two minds now whether to leave the motor/pulley arrangement as is (bridgeport), or remove the pulley section and mount the motor directly on top of the spindle with a drawbar through the motor.
28-10-2013 #119
Well I got there in the end but via a different route. I ended up buying two HSD router spindles which have a 30 taper and air powered atc. They are 6.8kw and 24000 rpm, and should have a fair bit of power run at slower speeds.
28-10-2013 #120
Both of these I presume?
The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
By Husky in forum Generic Chinese SpindlesReplies: 222Last Post: 22-01-2021, 06:54 PM -
motor power and chinese spindles power HELP
By DigiSoft in forum Spindles & Drive MotorsReplies: 5Last Post: 17-09-2013, 12:17 AM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM -
NEW MEMBER: Spindles
By Johnp in forum New Member IntroductionsReplies: 4Last Post: 28-06-2009, 11:46 AM
