    Why they only go backwards. . . . . . . . . Even Lewis whinged about it off start at weekend.! . . . . Anyway I've got a spare motoX gearbox that can just about handle 20K if your stuck. Lol
    why do we invent all these sports i ask you...
    DMM you can have a full 4 axis set 1000W motors and drives BOB, PSU,cables etc for $1600.!!. . .Not exactly comparing apples with apples due to lower RPM but still good price.
    http://www.dmm-tech.com/technology_solutions.html
    This is better set off Alibahbah . . http://www.aliexpress.com/product-fm...olesalers.html
    Yep you are right and with free shipping thats a real good deal... Im still trying to find a low profile motor with enough power to gear up and down around 6k and im not having any luck.. it looks like im going to get my atc but i will onle be able to draw pictures with the machine.... in ten colours of course..
    For that amount of money I'd want to be getting more than 12000rpm. 18000rpm would be much better, but it seems toolholders which are sufficiently well balanced for that speed are rare and expensive.
    This lot look worth investigating:
    http://www.alibaba.com/product-gs/54...g_Machine.html
    http://www.alibaba.com/product-gs/53...otor_BT30.html
    http://www.alibaba.com/product-gs/53...dle_Motor.html
    http://www.alibaba.com/product-gs/46..._with_atc.html
    http://www.alibaba.com/product-gs/36...dle_Motor.html
    In particular the first one - 1130-24Z or 1130-16Z. The 24Z (24krpm) has 35mm bore bearings, but the 16Z (18krpm) has 40mm bore thin section bearings. Need to investigate which is strongest. The one you have a quote for uses 45mm bore bearings, so it would be more rigid, but any of these will be more than the standard 2.2kw ER20 spindles which only use 25mm bearings. If they can't wind the -24Z for 220V then it'll have to be the 16Z spindle anyway.
    http://lyzyzc.en.alibaba.com/product...NS7CE1DDL.html
    First of all i dont really need 18k and None of the links you put on there are quotes, but just guide prices, get some quotes and see what you get, the item i have posted is without motor, i am awaiting updated paperwork for that, and is new unlike some of the links you have provided, they are used/refurbished items and as such very overpriced, i want BT30 ATC 12k rpm max (just for flexability) so if you can go cheaper price new not used, then post the quotes and i will contact them and may even buy one..or more
    Rick
    To Beat we have
    12k rpm spindle cartridge
    BT30 ATC
    $1522 = £976.52
    Oh just noticed three of your links are for Ms Xing....lol dont believe all you read will you
    Here was The quote she gave me...
    "Elizabeth Xing:
    (02:14:19):
    3.2 kw BT30 18000rpm spindle
    motor is 110mm, OK?
    Rick:(02:15:35):
    ok 380v
    spindle
    Elizabeth Xing:(02:17:26):
    2199 dollars per piece, not
    including the pull stud and toolholder.
    Sorry, 2177 dollars per
    piece.
    Reply View
    Context
    Rick:(02:18:10):
    and
    220v
    Elizabeth Xing:(02:18:20):
    the
    same.
    Rick:(02:18:43):
    Ok and what price for shipping
    to UK
    Elizabeth Xing:(02:19:31):
    Shipped by DHL, 249
    dollars.
    Package weight 23
    kg.
    Any questions???
  1. The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
    By Husky in forum Generic Chinese Spindles
    Last Post: 22-01-2021, 06:54 PM
  2. motor power and chinese spindles power HELP
    By DigiSoft in forum Spindles & Drive Motors
    Last Post: 17-09-2013, 12:17 AM
  3. Chinese spindles
    By Colin Barron in forum Marketplace Discussion
    Last Post: 23-08-2011, 08:58 PM
  4. Chinese 1.5kw Spindles
    By jcb121 in forum Generic Chinese Spindles
    Last Post: 28-07-2011, 06:20 PM
  5. NEW MEMBER: Spindles
    By Johnp in forum New Member Introductions
    Last Post: 28-06-2009, 11:46 AM
