Thread: Chinese Spindles
Well I got there in the end but via a different route. I ended up buying two HSD router spindles which have a 30 taper and air powered atc. They are 6.8kw and 24000 rpm, and should have a fair bit of power run at slower speeds.
28-10-2013 #2
Both of these I presume?
28-10-2013 #3
yes, both of those. I looked at a 10kw one locally and as it was 380v only I decided not to go for it, which after the auction had finished I regretted not getting it. Then those two appeared so it had to be.
The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
By Husky in forum Generic Chinese SpindlesReplies: 222Last Post: 22-01-2021, 06:54 PM -
motor power and chinese spindles power HELP
By DigiSoft in forum Spindles & Drive MotorsReplies: 5Last Post: 17-09-2013, 12:17 AM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM -
NEW MEMBER: Spindles
By Johnp in forum New Member IntroductionsReplies: 4Last Post: 28-06-2009, 11:46 AM
