back to the grind (pun intended)
been busy of late restoring a yamaha rd & trying to find a mill
now the search is over and ill have a centec 2 mill arriving in about two weeks time.
the centec is going to need a complete strip down and rebuild then it'l be converted to cnc :)
with the centec project looming, the pressure is on to get the boxford finished.
let me introduce you to my little friends...
ID:	6220Click image for larger version.
i dedicate two cheap 115mm grinders to the unforgiving job of paint removal and with the addition of one 'weapon' of a wire wheel i have one formidable setup.
the reason for using 2 grinders is simple, they have a tendency to overheat so i swap them over every once in a while.
the drill is used for getting into tight spots but it doesn't have the umph to compete with the grinder
today i started to attack the cabinet
ID:	6222Click image for larger version.
you can see the effect of the grinder on the top of the cabinet, like a knife through butter
in the next photo you can see the 'sump' (if thats what its called) too narrow for the grinder, the drill makes short work of this
i got as far as doing the top and front of the cab as well as the door then gave the stripped parts a lick of red oxide primer
ID:	6225Click image for larger version.
tomorrow i am aiming to have the rest of the cab stripped primed and the interior parts painted leaving the exterior ready for its first coat (if im lucky i may get 1 or 2 coats done)
you may notice the castors on the left hand side of the cab, these are just for ease of moving the cabinet
kudos to RNR for the grinder / wire wheel idea, i never thought of putting one on the grinder
