    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Hi Jazzcnc,
    Reading your answers on this thread is very helpful....IE speeds and feed rates. I have the 2kw Chinese spindle now, about to use it this week hopefully. I have ordered several 6mm single flute cutters. What about drilling through ali ? would it be the same setup and the same cutter ? what drilling method is best ?
    Hi Jazzcnc,
    Depends on the size of the holes. Up to about 4mm you can get away with good quality HSS drills, but any more than that is difficult because of the limited power these spindles output at low rpm's. Instead you have to use carbide drills, or mill the holes if they're big enough. Using a carbide drill worked extremely well for my bed hole array. I'm not sure if the flood coolant was required, probably could have got away with applying coolant manually if it wasn't so many holes:
    http://www.mycncuk.com/forums/router...html#post38578
  1. Question on PCB and routing
    By Fivetide in forum General Electronics
    Last Post: 12-05-2013, 06:35 PM
  2. NEW MEMBER: New to cnc routing and looking to buy a machine.
    By stamper in forum New Member Introductions
    Last Post: 03-12-2011, 03:31 PM
  3. PCB Isolation Routing
    By Mad Professor in forum General Discussion
    Last Post: 16-03-2011, 09:46 PM
  4. BUILD LOG: routing 3d?
    By proddy in forum DIY Router Build Logs
    Last Post: 03-08-2009, 11:20 PM
