Thread: routing aluminium help :)
04-06-2012 #13
JAZZ , My wet router is nothing special, going from bottom up it is steel frame + 18mm mdf board from wickes, painted thick layer of 2k paint + another plywood board( mounting one to which I screw all sheets and pieces) + waste 2-3mm mdf or cardboard. Recently, after maybe 2-3years, I replaced the mounting sheet - It's due too many holes in the old one. Plus there are steel and wooden border to keep liquid contained. Old swimming pool filter + cheapest 3 speed CH pump. Whole bed is slightly slanted to allow for nice return of coolant Does its job.
Kerosene is cheaper( I thing 1/2 price of diesel) but whole effort to find supplier - not worth it when petrol station is behind the corner
Robin, I use simple way of clamping - drywall screws with big washers. First I mount material from outside then mill all inside profile+holes, after this mount material from inside or through holes, remove outside screws then mill outsides.
Amateurish?? YES , but does its job
Question on PCB and routing
By Fivetide in forum General ElectronicsReplies: 20Last Post: 12-05-2013, 06:35 PM -
NEW MEMBER: New to cnc routing and looking to buy a machine.
By stamper in forum New Member IntroductionsReplies: 3Last Post: 03-12-2011, 03:31 PM -
PCB Isolation Routing
By Mad Professor in forum General DiscussionReplies: 3Last Post: 16-03-2011, 09:46 PM -
BUILD LOG: routing 3d?
By proddy in forum DIY Router Build LogsReplies: 2Last Post: 03-08-2009, 11:20 PM
