28-11-2008 #13
I agree Jeremy. The point is that Lee wants a bench supply with a specific capability. If I was making a fixed supply then the LM338 is an ideal candidate. IF you want full output current to a given spec over a wide voltage range then linear regulators arent going to cut it. All depends on whats required. If Lee wants to reduce his expectations to 0 - 20v at .5A max guaranteed then the LM338 will do the job without overheating across the range. If he wants >1A output guaranteed then the LM338 isnt the way to go.... as the heatsink will be more expensive than the rest of it all together....
There is a secondary issue - is the goal just to produce something that'll 'just about do' or also to learn more about how to design a proper supply?
Irving...
Mach 3 control panel help
By IanParkin in forum Artsoft Mach (3 & 4)Replies: 19Last Post: 05-09-2014, 04:05 PM -
Control Panel Guidance
By GTJim in forum General ElectronicsReplies: 2Last Post: 03-09-2013, 08:42 PM -
RFQ: Aluminium Control Panel
By m_c in forum Projects, Jobs & RequestsReplies: 5Last Post: 27-04-2013, 08:46 PM -
Advice Needed - Control Panel
By GTJim in forum General ElectronicsReplies: 0Last Post: 18-04-2013, 08:23 AM -
Small panel for my CNC
By jcb121 in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 19-02-2012, 12:21 PM
