28-11-2008 #18
Eddy, I didnt miss the point - if its a motor controller is not dissipating 60w continuously, as its almost certainly a PWM arrangement. Its only dissipating that wattage during the 'on' cycle at a high frequency. take for example a common controller chip from ST. Its capable of 30A without a heatsink... but thats because the switching frequency is 10khz. for a single pulse at that frequency the thermal characteristic is <0.1degC/W so a heatsink of only 16sq cm of copper on the PCB will suffice to keep the mean junction temperature below 125degC. You could never run a linear circuit at that sort of load. The actual static chip thermal resistance is typical at 15decC/W... at 60W the jiunction temp would be 15*60deg over ambient = 900deg... it would have long since melted!
For the record I have designed systems for both miltary (-55 -> +125degC) and space applications (-100 -> +250degC)!
Mach 3 control panel help
By IanParkin in forum Artsoft Mach (3 & 4)Replies: 19Last Post: 05-09-2014, 04:05 PM -
Control Panel Guidance
By GTJim in forum General ElectronicsReplies: 2Last Post: 03-09-2013, 08:42 PM -
RFQ: Aluminium Control Panel
By m_c in forum Projects, Jobs & RequestsReplies: 5Last Post: 27-04-2013, 08:46 PM -
Advice Needed - Control Panel
By GTJim in forum General ElectronicsReplies: 0Last Post: 18-04-2013, 08:23 AM -
Small panel for my CNC
By jcb121 in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 19-02-2012, 12:21 PM
