Thread: Auto zero Z axis problems
03-06-2012 #5
Ok I just checked both the simple Z Autozero routine and the main tool change routine and both are set to 250mm/min fast probe and 25mm/min slow probe so you shouldn't be getting this problem unless your routine is cocked up or the probe/plate is dodgy.??
Z AXIS, big tex blue screen and auto tool sensor Problems
By Tomnewry in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 01-01-2014, 09:01 PM -
What Spindle / Auto Tool Changer?
By Chaz in forum Tool & Tooling TechnologyReplies: 11Last Post: 01-08-2013, 10:35 PM -
Boxford VMC190 Retrofit Problems, axis sounds very rough
By mikegolding in forum Boxford Vertical MillsReplies: 5Last Post: 09-06-2013, 09:11 PM -
any one know about auto lube systems?
By graffian in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 02-03-2009, 05:52 AM -
Auto spindle lock
By Robin Hewitt in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 30-08-2008, 08:15 AM
