Thread: few questions.
03-06-2012 #6
Johns rounding over bit suggestion would work easily enough for that lever using a profiling toolpath but only cutting the area of the bit that you grip and not the cable clamping area.
I would make a copy of the lever profile and paste on a new layer then cut away the bits you don't want and use these lines for the profile toopath to follow using an open vector option. . . . . Will be dead quick and simple.!!
Edit: You will still obviously need to do two sided indexed machining and tabs located half way thru the lever.!!
questions...questions
By victorismyhero in forum Machine DiscussionReplies: 4Last Post: 16-07-2013, 06:44 PM -
I want to DIY.. some questions please!
By Tenson in forum Gantry/Router Machines & BuildingReplies: 95Last Post: 24-04-2012, 10:10 PM -
NEW MEMBER: Hi all just a few questions!
By dubchip in forum New Member IntroductionsReplies: 17Last Post: 02-12-2011, 10:47 PM -
By dubchip in forum New Member IntroductionsReplies: 3Last Post: 10-11-2011, 03:40 PM -
New in CNC and I have some questions
By demestav in forum General DiscussionReplies: 0Last Post: 14-09-2011, 12:19 PM
