    I’m looking for a machine with a cutting bed size of approx 1000x500mm. The machine is for general hobby use and therefore is required to cut Wood, Plastic and Aluminum. I would appreciate your view or experiences on the above from www.cnc3axis.com
    Standard accessories included:
    • NCStudio Software, cable and controller.
    • Communication cable
    • Water Pump
    • Power cable
    • Clamp: 4 sets
    • Wrench: 2 pieces
    • Collet 1pc& adapter( for ф3.175 to ф6 )1pc
    • Bits: 8 pieces (6 pieces Flat bottom bits, 2 pieces Two spiral flute bits
    Spindle spec:
    • Spec: 65*210 mm (Diameter:65mm x Length:210mm)
    • Power: 800W
    • Voltage: 220V~250V
    • Frequency: 400 Hz
    • Speed: 8000-24000 R/min
    • ER11 collet chuck
    Stepper drivers:
    • Input Voltage: 220V-240 V, 50/60HZ
    • Output Voltage: 0-240 VAC
    • Output Power: 1.5 KW
    • Output Frequency: 0-400 Hz
    • Output Current: 7.0 A
    • Capacity: 2.8 KVA
    • Overload Capacity: 10.5 (60s)(A)
    Stepper Motors:
    • Step Angle: 1.8 degree
    • Voltage: 1.8V
    • Current: 3.0A/phase
    • Resistance: 0.50hm/phase
    • Inductance: 1.8mH/phase
    • Static torque: 16.5kg-cm
    • Number of wire leads: 4
    • Length: 106 mm
    • Click image for larger version.
    • Thank you
  1. CNC machine "Spanish" model . Advice and opinions needed!
    By shapebusters in forum Machine Discussion
    Last Post: 12-03-2014, 06:21 AM
  2. The Journey begins.. new to me.. my first CNC - Black Cat
    By Fivetide in forum Milling Machines, Builds & Conversions
    Last Post: 22-10-2012, 05:48 PM
  3. Has anyone got/used a machine from Black-Cat-CNC?
    By cjpwart in forum Milling Machines, Builds & Conversions
    Last Post: 12-08-2012, 05:15 AM
  4. Opinions sought on cheap desktop PCB milling machine
    By ksangeelee in forum Milling Machines, Builds & Conversions
    Last Post: 16-03-2012, 01:57 PM
  5. eBay: 2GB USB Flash Memory, Swivel Stick (black)
    By Lee Roberts in forum Items On eBay UK
    Last Post: 17-12-2008, 05:34 PM
