Thread: Drilling Acrylic with CamBam
06-06-2012 #3
What I've found when working with acrylic is that there's two types ....cast acrylic (which doesn't melt easily) & extruded acrylic (which is twatful for melting & gumming up the drill/end mill)...so my first top tip would be to make sure you buy only cast acrylic for using with CNC/drilling etc.
If you still end up with melting using cast acrylic, the only other thing I could suggest is to first drill with say a 2.8mm drill (and due it to doing all the work, may result in some melting of the acylic), then take out the final 0.2mm by using a 3mm bit ...because it's not having to do much work you can therefore descend quickly & stop any melting (kind of like a final pass)
Setting rapids in CamBam
By swisscheese in forum CAD & CAM SoftwareReplies: 4Last Post: 04-04-2014, 02:30 PM -
Mach3 / cambam
By dudz in forum Artsoft Mach (3 & 4)Replies: 5Last Post: 01-04-2013, 06:02 PM -
Acrylic or mdf I can cnc
By rainboweyes in forum Opportunities Available & SoughtReplies: 0Last Post: 19-02-2013, 02:09 AM -
Cambam / milling Alu
By dudz in forum CAD & CAM SoftwareReplies: 5Last Post: 23-12-2012, 05:22 PM -
How do i make this in cambam?
By motoxy in forum CAD & CAM SoftwareReplies: 4Last Post: 09-02-2012, 06:01 PM
